Tutorial The right settings
Bob de Bouwer
Netherlands
Am I using the right settings?
Do you notice that your download speed is sometimes a bit lower? Or do you ever have connection problems? This may be due to outdated settings.
It is good to check your settings every now and then. Especially if you have been a customer with us for some time. You may then still use the same data as you set in the beginning and that can cause minor malfunctions.
What data do you have to enter?
Download:
  • Server address : news.hitnews.com
  • Port : 119 / 563 (SSL server address remains the same, so no ssl.hitnews.com)
  • Connections : 100 (If you use fewer connections in your download program, your speed will decrease.)
Upload:
  • Port : 119 / 563 (SSL server address remains the same ssl.hitnews.com)
Spotnet:
For Spotnet users see below:
settings-spotnet-jpg.140
So if you use our service, it should look like this.
If you still have questions, you can always reach us at the forum: https://forum.hitnews.com, or via support support@hitnews.com
